Boost reading via VagCom
Is it possable to get a boost reading from VagCom? I don't think it is as theres no sensor there by default but thought I would check in case I'm been thick. :D
Cheers in adavance.
Been having a play this morning & not sure if its because my brains still in bed but I can't fnd any where on the engine module anything that says Boost Pressure, now I have found Intake air Press & Actual Intake press.
Is this the boost pressure? If it is then am I right in thinking that its reading 0.9PSI on the screen shot?
Sorry if I'm been slow here but it is a Sunday. :D
Doc1.doc
that's reading atmospheric pressure which on that day was just under a bar, this is because the car doesnt produce boost at idle!
Log the car through a 3rd gear pull and minus 1000 from the boost readings as they're true pressure of both atmosphere and boost.
