Something in my boot?!
Odd one this...
Driving to work this morning I noticed a knocking noise coming from the back of the car (boot) when going over the uneven roads near my house .
It basically sounded like a large loose box moving around in the boot.. however there is nothing in the boot. I noticed when putting some weight on the rear suspension I can hear a metallic pinging noise, any ideas?
Malc
Bust spring maybe?
Scrabble under the back of the car and have a butchers.
Could it have split one of the top suspension mounts?
Agreed; that sounds very much like a busted spring or split top mount. Easiest and best to inspect the rear springs on a 4-post lift.
let the wife out of the boot?:D
Cheers, indeed looks like nearside rear spring/mount.
Chuck it up on ramp tomorrow to have a look... I assume I wont destroy car driving on it.
Gently, and no further than necessary. Apart from possibilities of spring through mount or falling out if the car goes really light over a crest, the corner weights and rear roll resistance, and hence handling will be all to ****!
Well had it up on the ramp and it actually looks like the rear anti roll bar I had fitted...
The bolt from the bar is knocking the existing on the left side, I guess I'll see if the garage I had it fitted at can cut the bolt down a bit.
All sorted :)
The bolt from the rear arb was sitting too close to the existing which runs through the shock and it looks as if it had worked its way loose.
Put a spacer on the new bolt and tightened it all up and its good to go
