Rear Light Removal
Ive tried to remove one of my rear lights due to a crack in it and it just doesnt want to know :(
Ive removed the 4 bolts and it comes out slightly, but then seems to get stuck at the bottom for some reason even though it looks like there is nothing holding it in.
Can anyone help me with this ?
You may have to move the small plastic trim piece just below the light 1st.
How is this removed ? :(
It either just pulls off or there may be something to undo form the inside.
From memory you have to remove the plastic trim from outside UNDERNEATH the boot lid hatch opening...........With this out of the way you can now slide the plastic trim from below the rear light unit towards the centre of the car - It will slide out of the mounting holes. I think there is a Torx screw visible when you remove the centre trim piece which secures the trim under the light unit..
Thanks for this eddies :thumbup:
