Lack of heat from my heater
Hello,
I am only getting lukewarm air from the heater of my vRS. All other components of the heating system are working, it's just not producing very warm air. Any suggestions/solutions?
Cheers,
Stefan
I must say when the AC is on the hottest it is no where near as warm as the regular heater on my VRS.
My Fabia appears to have just 3 settings for the heater (I have air-con (which is never used) but I think it needs recharging). Its either cold, warm (dail turned to about 15 degrees), or suffercatingly hot.
Air con should be used for at least 10 minutes each day. The lubricant for the seals and pump are part of the R143a gas. If not used, seals dry out and the systems leaks. Most systems loose about 15% of the gas each year though.
I must be lucky because the heaters in my vrs are lovely and hot :D
Iv noticed over the past week or so that it takes longer to warm up though with it being so cold :(
