Fitting wheel trims to original Skoda wheels
Hi,
I have the original steel Skoda wheels that were supplied with my 1997 Felicia. They are domed shape with a centre hub piece. I was wondering, if I remove the centre hub, would normal sized wheel trims fit the wheels. It's just that the wheel seems to be very domed shape and i am worried that they won't be able to sit on the wheel. Any help will be very appreciated.
Many thanks
Ian
if you remove the centre cap they will definetly fit but they,ll be a bit loose so you,ll have to use cable ties:santa2:
Be wary though as not all wheel trims will fit! I made this mistake on my fabia. But most of them will. its just the shape of the wheel that makes it hard for some trims to fit onto the wheel. Most motor factors are decent and will let you take them back if they dont fit. Or just do what I did and spray your wheels gloss black
