Noisy Vrs gearbox in Neutral on Tickover
Well. :(
Had the car just over a day & noticed a Shuddery thod type noise from the gearbox when ticking over in neutral.... Now. This noise is similar to what i have heard before both on a Fiat & a vauxhall that i owned which both had Dual mass Flywheels :rolleyes:
When i first looked at the car & listened there was nothing, it sounded quite sweet (For a diesel) But tonight it was quite apparent & dissapeared when the clutch pedal was depressed (Like me now).
I take it my Dmf is grumbling :rolleyes:.
The car had stood for 12 Hrs + & when i moved it up The drive & let the clutch out the noise had dissapeared, Hmm i thought, lack of oil circulating ? But realising they have a Dmf fitted, Im sure it's more likely that & seeing as the car has covered 92k !
I shall have to notice if it does it when the engine is hot ! Although again, i did not notice it yesterday at all :(
Thoughts please ?
Dean
hmmm dmf probable, gutting chap
I've got the same problem, so please update if you get any more info, cheers.
EDIT - Found this, YouTube - 3D animation of dual mass flywheel can anyone tell me which part causes the clunking, is it one of the springs thats damaged?
Because i think ill be trying this job myself with the assistance of a mechanic mate to cap the labour cost.
Edited by vrsmeansyellow
DMF usually sounds like someone is belting the engine with a big hammer. The flywheel still turns when the clutch is in, so if the noise goes away completely with the clutch in, I doubt it's the DMF unless it's just starting to go.
Might be gearbox bearings. I would have gearbox oil changed and go from there. I would also check the engine mountings, especially the rear dogbone mount.
I think it is just starting to go, as my vauxhall Vectra Cdti 150 started the same & progressively got worse with more of a knock being heard, I will change the Gearbox oil though & see if it make's a difference.
Dean
I do believe that not all are springs, Some have a gel type pack which absorbs the shocks Etc. The springs/packs become worn allowing the 2 Flywheels to chatter Etc ..
And to think, Cars managed perfectly fine for Decades on Good Ole Steel Flywheels !! :rolleyes:
Dean
Here you go.
Perfect Example on a Vw Tdi !! :rolleyes:
YouTube - Bad VW TDI DMF
Oh, & A Good One :)
YouTube - GOOD VW TDI DMF
Still Sh!te in my oppinion. Anything that is under heavy loadings that already has play in there will eventually get fatigue & become more problematic ...
Dean
All DMF's are bad /\
I Couldn't agree more if you paid me :D
Dean
Sounds like clutch release bearing to me.
