Lowering advice
hello long time, but its me again =D
Im looking at lowering my Fabia, but need some advice to how much i should lower it by, has any one had any problems for more then 50mm?
or should i stick to 35mm? or 40mm?
Many thanks
:thumbup:
  • Replies 53
  • Views 4.8k
Many thanks
:thumbup:
jamex extreme coilovers £330-400, 20-60mm adjustment,
ive lowered mine about 55mm, no probs.
Any pics?
Cheers,
Josh
it only gets impractical when you wind the coilovers really low,i recon i'm running mine at about 60mm with no worries,whereas it was wound all the way down at first and speed humps were a small problem for comfort,and with the 17"s on and 215/40 tyres it scrubbed a little i would recon when first done it was around 90-100mm lower
ahhh brilliant, coilovers are an issue but ive found a rather good suspension kit wich will drop it around 50mm so should be ok then, you bos got any pics of your fabias?
If you go too low dont you have to do the drop links too?
Mines as low as it went (on the back anyways) another 10mm on the front ... i'd say this was about 100mm maybe??
well anyway it was aweful...
now im running around 60/70mm maybe?? and its bob on :) the yellow one is maybe 10-15mm higher
No, just depnds which suspension set up you run.
Im all the way down front and rear on my coilovers -75mm.
When running the 17's there is no problems with catching on anything.
On the 16's i cought on speed bumps and cought the subframe on some roads.
I dont run an undertray now, as its pretty smashed up.
But with -50mm on 16's or 17's you'll have no problems at all.
80mm rear 50mm front, now 50 all round ill get a fresh pic later,
ive got 16's on,
the jamex extreme's come with the drop links.
Om nyom nyom nyom
I LIKE!!! will have to look at spraying my alloys until the kerschers arrive! :D
Whats the cheapest you could lower for?
ive got 16's on,
Some mega reverse rake going on there.
Keep the nose down lower then the back.
I can get coilovers for £240! ;)
What size Rims you running your car on? would be good to know so i can get my machine looking good.
do these fit fabias.. that is the question any chance these are the ones from Club polo?.
Im looking at the Vmaxx coilovers for around 360 quid they lower it up to 65mm both ends probably enough for what i need.
also there are Gmax coilovers.
what are the jamex ones like any good?
:thumbup:
:thumbup:
Im running Vmaxx.. good enough for what i want them to do... and they go quite low :) lower than KW V1's anyway :)
also the top wheels are obviosuly std vrs 16" and the other 2 are 17's with 205/40/17 tires :thumbup:
-30mm on Eibach Springs and standard shocks
Oh, and a few cases of beer in the boot :rolleyes:
if you read,
'' now 50 all round ill get a fresh pic later'',
its more 55mm all round, that pic was taken with no rear adjusters as they was missing from the package, hense the super lowe back end.
i rate them, they dont dive loads round corners, they dip then hold nice. im really pleased with them, proformance/price wise there bob on. so much better than the standard stuff, But my fab is NOT a VRS, its a tdi pd100,
Now that baby is pimp,
:eek:Where did you get those badges from?:thumbup:
haha sorry yes i meant the second picture =]
excellent thank you ill make my choice over the festive season. I'll get some pics down too.
Just need to decide on my wheels =D
btw ahs anyone ever ordered from www.superskoda.com?
....i hate this thread and this forum........ i just went and bought som AP coilovers..... LOL...ssshhhh dont let the mrs know :D
here mine lowered about 70mm
and here lowered about 100mm,as has allready been said it was useless
and an underneath shot
lowered on kw v1 coilovers,no droplink problems at all:D
excellent so ive decied im gna go for a 60mm drop with 16" alloys. should be ok.
these alloys:
POTN - If you are looking for an BK Racing BK299 7.0x16" Silver Set of 4 wheels and tyres click here BK Racing
And Gmaxx Coilovers for £400
any other ideas? any more pictures with peoples ride heights would be excellent, i looked on the fabia alloys thread but not all of the ride heights are noted some look differnt to each others even tho some reckon they have less and what not.... Crazy :)
Oh and do many of you use the droplinks when you've dropped your car more then 40mm?:o
if you look on this blog,about 3/4 of the way down the page you will see my car as it is now,70mm front 50mm rear,with the pics taken by someone who knows mre than me on photograpy,you may want to read the small feature too:D
Dogboxmedia 2008 October
