Running Problem 1.3 felicia mpi
Hi Guys i'm a newbie and i have a problem with my 1997 1.3 mpi felicia. I love this little car, however sometimes when the car gets hot and i then turn if off and come back to it a few minutes later the car then judders like its running on 2 cylinders. Its starts well both hot and cold. When its doing this if you pull up, the car revs itself up and down like its blipping the throttle and when you drive its like the throttle is stuck. I can do long journeys no problems but if i do say 5 miles leave and then restart it, it does it. Any ideas? I did read some other threads, so will disconnect the battery and check the throttle cable.
I really did appreciate the headlight info as mine are pointing down.
Thanks for any help much appreciated.
Forgot to add, its done 65,500 miles and has got a service history.
Edited by Gilley
Thanks, will do once i work out all the areas of the site.
Welcome. Hope you get it sorted.
Welcome to Briskoda
davy
welcome along
