1.8T screech at start-up?
only when its cold and not been run for a few hours I get a screech that last less than a second as the engine starts.
any ideas? ill be chatting to mechanic soon but thought id ask for possibilities?
Alternator belt............Mines doing it as well .....my plan is ignore until the weather warms up then it will stop.
HTH
Hi Rich
Sorry to hear you are having trouble with your VRS.
Sounds like the sprag clutch on the starter motor ( one way clutch for protection ) annoing noise only cured by fitting a new strater motor.If you can live with it it will cause no issues in the short term
Let us know if this is backed up by your fitter.
Have a great new year.
Sounds like a starter motor.
Hi Rich
Got to agree with that, pretty common.
Hi Rich
Ooops missed that post. :o
HTH
Ha good plan, if its good enough for Fatty then thats what I'm gonna do:P
But i also have this starter screech, my car embarrasses me on a morning :o
My Arosa developed the same problem. It was the spray clutch not disengaging when really cold and fixed itself in the warmer weather. My Octy does it as well.
Chap at the top of the street has got a VW 2.0 Petrol and does the same. Been screaching all year long and it still runs fine.
I gave mine a clean last month which seemed to shut it up, but now it's -2 degrees outside in the mornings it's doing it again. I wonder how much they are to replace and if I can get it done under warranty... :confused:
Starter motors arn't usually cheap :(
Mines scretched since i have owned it, thats two years now, its never got any worse or caused any probs.
One of those things that isn't going to kill your car but is still f:censored:ng annoying :rolleyes:
Oh well, at least I can entertain the street at 8:00 in the morning with my screeching starter motor and mooing rear brakes :rofl:
It might not kill the car, just may not start one morning.
Genuine starters are around £100 iirc.
cool think ill ignore it then for the moment and see if it stops when it warms up as it doesnt really bother me tbh just making sure nothings is about to launch out of the top of the engine bay one morning! and doesnt sound to bad if it does go one morning for a replacement.
thanks
:rofl: Yeah mine's the same, very annoying though sometimes!
yep, my 2.0 fabia does it too, tis annoying but i aint gonna fix it till it blows up
my vrs does it, annoying sound isnt it. Not going to fix it til it breaks and once the weather gets warmer it will go anyways :)
Mine used to do it!
But I removed the starter and cleaned it up, and greased the shaft (oooh controversial!).
It's been flawless for the last 6 months. Not heard a schriek since.
Using Castrol LM grease works, although most people try and tell me it doesn't!
  • 11 months later...
Hi mine started with a little screech a week ago,progressed to a horrible sound now.
glad i've read this always thought mine was the alternater belt slipping on startup, presumed either the belt or tensioner was on its way out
Mine used to do it... fault was the a/c compressor clutch. New a/c compressor fixed it!
Covered under warranty, thankfully! Invoice amount was £900!
id say its the starter
Yup starter ... Mine does it too but it aint broke yet so wont be fixing just yet lol
Yeah mine is the same getting worse in the cold weather! So are my bloody annoying mooing brakes!!!!!!
