90c Temp But Heater Blows COLD
Hi Guyz,
Id really appreciate it if anyone could give me a few pointers as to this condition.
Temp light is beeping & flashing.Temp is constant 90c.But NO HEAT...
Effin Brilliant timing innit...Its colder inside my car than OUT :eek:
Havent the £££s for Skoda dealer.:mad:
Thanx In Anticipation...Tony
1.6 Octavia Ambiente Estate :thumbup:
Hi Guyz,
Have you checked the water in the Radiator ?
and if it is empty you have a leak, you need to do a presure check to see where is is comming from
Radiotwo
Sounds like you are low on coolant, something which needs fixing ASAP. You maybe overheating parts of the engine due to lack of coolant flow.
Based on what that did to my engine, top up that fluid asap, and with the right stuff - I'd avoid driving that one if it is too low. All too easy to get an airlock otherwise.
The reason you get no heat inside is that the heater matrix has insufficient (warm/hot) coolant going through it. The reason the engine temp is way too high, is for the same reason.
Thanx...What coolant should I use???
And can I do it myself...I know Nothing about engines....:thumbdwn:
Tony
I would check the water pump/flow/temp drop across the rad.
i'd put water in it then get it along to a dealer to have it replaced with coolant flush and leak checked!
pretty urgent to
you could blow your head gasket!
