Vagcom fault code - 01336
Guys / Gals - Lots of corrosion around the 3 connector blocks under the CD multichanger (due to leaking screenwash tube). Had loads of problems with the central locking which now seem to have gone away now I think I've fixed the leak, dried it and rewired a couple of connections that had corroded to destruction!
Anyhow, just new to the whole vagcom thing, but the only fault code left which will not go away is:
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
This appears on the following controllers:
Address 17: instruments
Address 19: CAN gateway
Address 56: Radio
The scan was done with the engine NOT running if that makes a difference?So, is this code anything to be concerned about and any obvious places to look to rectify it?
Bearing in mind the point above regarding the corrosion around the connector blocks in the CD compartment, there is a high chance it's somewhere there, but anyone know which coloured wire it is or even which connector block to concentrate on (cream, darker cream or the black one?)
Any help, as always, much appreciated.
Bump !
  • 3 years later...
Hi Schmooser, did you ever solve this?
I'm getting this at the mo, also trying to get over the washer leak which seems to have caused some trouble!
Address 46: Central Conv.
Controller: 1C0 959 799 B
Component: 4Q Komfortger·t HLO 0003
Coding: 00259
Shop #: WSC 31480
4 Faults Found:
00932 - Electric Window Motor: Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
End
  • 2 years later...
Hi, new to the forum. I have just taken ownership of a Mk1 Octavia 1.9 TDI PD 130 and I have the very same code errors as the OP in the same addresses. I have been told that it may well be dodgy connections/wiring within the door panel or under one of the seats, or maybe the Convenience Control Module.
Anyone with any ideas and/or solutions? Would be much appreciated :)
  • 3 years later...
hi if no one has solved this and is still interested iv had 2 skodas and this error is common because of the comfort control moduel or the pins need re wiring
