Rear Wiper Nozzle Missing
There was no water coming out of the rear wiper assembly so i checked and there was a leak under the expansion tank under bonnet. I re-connected the two parts of the hose and was thought that would be it.
When I tried again, there was a feeble excuse for a water jet coming out of the wiper assembly.
On inspection it appears that I am also missing a nozzle, are they easy to come by, if so any idea where i could get my hands on one and do I need to but the whole assembly.
As I hadnt taken notice of it before Im not too sure what all is missing (apart from the nozzle).
You can get a new nozzle from a Skoda dealer and should be only a few £. You may find that the old nozzle has broken off, leaving the stem of it in the pipe. You should be able to remove it by gently screwing in a suitably sized self tapping screw and pulling it out with a pair of pliers on the head of the screw.
If the brass piece of nozzle has broken then the whole piece is NOT available as a seperate piece only the Jet nozzle is :thumbdwn:
Mine had snapped in half and the dealer took close to £90 for a new wiper motor:eek:
thanks for the info, does anyone know if an octavia or possibly seat ibiza use the same part. Thinking about getting one from a scrappy.
i had this on my fab when i picked it up
had no spray so chacked all the pipes and foudna popped join.
reconnected the pipe and tested to find that i was also missing the nozle and cover from the washer arm meaning the jet of water shot out at right angle from the boot about 6 feet.
Now as fun as it was spraying some tailgaters (you should of seen their faces! :eek:) a trip to local deal and a both parts were about £7
i tried to get the same bits of a polo and golf but niether were the same shape
Nightmare,
Looks like I have the same issue as you Sifelicia. The small brass pipe / nozzle has sheered and Mr Skoda is looking for £70 for a new motor.
Has anyone had the same problem and successfully got a suitable replacement motor / part from a scrappy. If so what mak and model did you go for.
cheers folks
Try David at the skoda shop Here He gave me this reply when mine was broken but unfortunately for me i had already bought mine:(
If only he came to me, He could of had not only a brand new one, but posted out to him for a total of only £69.68.
and yes gents that is with VAT and Postage and the part.
IF you need ANYTHING please dont hesitate to give me a shout on the Skoda Shop Forum or even just PM me
Thanks for reading
Regards
David Aumais
