Water Injection upgrade kit fitted - review
Hmm, don't know yet how much of it is used for eg. 100 miles, but if it will consume considerable amounts I think I will start doing alcohol on my own :D isopropyl is indeed quite expensive, and at devil's own they say that cheap vodka can be used, so why not to make one on my own ;) Anyway, first I need to check on what brew ratio the power increase will be best.
6gph is hell of a lot! I only have the 3gph nozzle and that chucks enough in for me on full throttle. :)
Now it sound more real for me, I made about 20miles today, and didn't push the throttle too much, going max 100mph and it consumed about one gallon of the brew:eek:
How much do your cars take?
need to fill up the 5l washer bottle almost twice for every 50L of derv.
Could get a tad more out of it by raising the startup and full-flow points but it's doing so well with the 49 deg C temps we're enjoying out here in Bahrain ATM....
weather permiting i will be fitting my 5ltr washer tank tomorow and also replacing the check valve with a solinoid valve because im fed up running out and not knowing and then having to bleed the system ... again
oh and i still have about 10 ltrs of methanol left so that should be enough to get a few test runs done :D
That much would be ok, I have used over 3 liters of brew on about 3 liters of derv. but the system was setup to start at about 0,5 bar:D It gave excellent result, the car ran more soothly and had more power, but I would went bankrupt on isopropyl:cool: Also there were a white smoke pop-outs from the exhaust when stopped accelerating:D
This week maybe I will manage to do some dyno tests.
  • 2 months later...
Anyone got any confirmed increases in bhp/torque figures? Basil, would you say thats the best place for a pre-turbo set up? As myself and Tom.w thought the same (well he did and I just agreed as didnt look into it!)
Hopefully fitting my kit at the weekend, and should get some 1/4 times & RR runs in the coming few weeks.
