Fuel Gauge not working at all.. plz help
My fabia has suffered over the last few days,
had to drain the tank due to wrong fuel and now the fuel gauge registers empty all the time (although there is no fuel warning light on)
i have taken the fuel sender out and moved it up and down manually but still nothing ( i checked it and it is working according to a multimeter testing resistance
for some reason the coolant light flashes on the instrument cluster and it never did before all this ( i have bridged the connector with wire on the coolant tank but i still get the flashing light, the only thing that remedies it is to unplug the fuel sender unit
im lost as to what it could be
id be really grateful if anyone could help... i dont want to waste money on a new sender unit if it could be something else
thanks everyone
Hmm. . . if its working at the correct resistance then i asume its working. Possibly a fuse gone?
I always start there. . . lol
anyone know if there is a fuse related to the fuel guage - i would have thought that it would be for the whole instrument panel.
will take a look
any other suggestions welcome
£10 prize to anyone who comes up with the right solution!
thanks
Tom
IIRC, the coolant temperature sensor, fuel guage sender, washer fluid level sensor and coolant level sensor all share a common ground from the dashpod (Brown/White). Given that all the activity has been around the fuel tank I would look there. Follow the ground wire from the fuel sender.
thanks will get straight on it when i get home
£10 might be on its way to you!
thanks again hope i find something simple
Yeah, sounds good to me - if in doubt, always try to revert to 'last known good' (or in your case 'what it was like when you last knew what was wrong!' :doh: )
