Climatronic and cup holders
Whilst researching Climatronic codes I came across the following site which contains an explanation of how the Climatronic unit works. Anyone thinking of fitting a second cup holder to the dash would be well advised to have a look at the fifth frame. Now I'm off to see if I can find the source of that information...
http://hem.passagen.se/vf1000/CLIMAtronic.htm
Useful Denis. :thumbup:
Picture shows the cup at the bottom, climatronic up to :confused:
Having had a jolly to Europe this weekend with a "friend", we discovered that the standard octy cupholders are sh
Get your "friend" to hold the cups, job done :)
Assuming your "friend" has a free hand or 2 of course :naughty:
If the golf ones are the same as the Bora then they are alot better than the vRS ones. If
only i had my vRS, its still not here. :-(
As we are in climatronic mode, is it possible (does anyone know..) if you can retrofit the newer dual zone climate in place of the original single zone such as my Superb has?
ps....dont know anything about cup-holders.
What cupholders does the Superb have? Or for that matter the new Octy?
We dont as such, just 2/3 moulded types in front of the handbrake which are perfect for holding sunglases or mobile phones.
Not sure about the new Octy tho.
Hey chaps,anyone interested in cup holders should look here
Clicky
can't seem to link straight to it tho so u will have to go
Online store > Product overview > Aladdins cave
they are the first item on the page.The item seems to replace the cubby under the head unit with cup holders and a smaller cubby.Quite cheap too.
I saw them on there the other day, anyone fitted them?
Think I might order some and see what happens :D
Had a look on VAGPARTS am very tempted by the cup holders.....sad but true ;).
Should fit as the unit is a standard single DIN size and should replace the cubby under the stereo.
Also been toying with the idea of getting the R32 trim for the centre console but seeing as it comes in 5 parts it wouldn't have fitted. However VAGPARTS now do the double DIN unit for the centre console.....a plan is hatching ;).
What does the R32 trim look like then?
Real brushed aluminium IIRC.....got to say the Octys fake carbon fibre surround looks on the wrong side of naf.
I didn't think the carbon looked to bad, looks alot better than the fake wood my uncles Passat
Only problem I see with the Vagparts cupholders is they will interfere with the gearshift unless you move the radio into the lower slot.
