clutch .vrs octy
greetings. has anyone out there had any proplems with there clutch at 45k like its stretching sounds weird; but every time u put your foot down its like a rope been stretched....
Sounds like the clutch is FUBAR. I changed mine at 50K.
Was going to say it sounds like the cable is on it's way out but.....seeing as Obi Wan replied...I'll keep quiet. ;)
mine went @ about 50k too
Changed mine at 30k
Oooh good thread Conor :)
Could any of you wise ones tell me whether you went for aftermarket items and if so which... ooh and who did you get to fit them ?
(I can feel mine starting to slip and would rather pre-empt the strike than completely burn it out Austin Maestro banger style)
Both of mine went before 40k and the third one will be replaced this weekend with a bit of luck. :D
I'm just approaching 35k ... any advice Des ?
53k here :wave23d:
Changed for an uprated Sachs one from IP :thumbup:
Same here - uprated Sachs clutch + lightened flywheel from IP. Probably best to get it fitted locally to you.
so i can expect mine to be on its way out already????bl00dy hell 36k on the clock,now revo'd and driven "briskly".
how much are new uprated ones?and how long can i expect the new one to last?
Mine's at 58K now, but no sign yet?!?!? Or perhaps I just don't know what a knackered clutch drives like ;)
I'm now at 45k and clutch is still going strong. No need to worry Jason.
