personal reg question
My son has just bought a Nissan Silvia (which is an import),to replace his terminaly rusty 200sx.The question is that it had a personal number plate which was removed when he bought it,and it now has an M registration on it.His old 200sx has a personal plate starting with N 200 will he be able to fit this?. N making the car appear newer,which is a not allowed.But the V5 states manufactured xx/2005,first registered xx/2008.Normally I would of thought that the first registered date is the one you cant put a reg newer than on,but are imports treated differently?
Could be worth a phone call to the DVLA to clarify that one.
You cannot make a car appear newer than it actually is. If the date of FIRST registration is after August 1995 then he can use the N reg plate. Otherwise not. Even with an import
Also note that the car you want to transfer from (in this case the 200sx) must have a current valid MOT certificate otherwise you cannot transfer the registration number.
if the car currently has an M registration, and this was allocated by the DVLA then it will not be possible to transfer an N registration to this car.
unless you can prove the date of manufacture was after August 1995...
