RNS Columbus
Hi just fitted a RNS 510 columbus into an Octy 2, the only problem i have now is my 6 disc CD changer audio is very distorted radio and SD card audio are fine and did not do this before with my old radio so im presuming may be a set up problem?
You'll probably need to re-wire the quad block connector slightly - very easy to do.
Have a look on Stu's site: (towards the bottom)
http://www.octavia-vrs.com/technical/mfd2.html
I managed it and I'm an electrical idiot :)
Correct me if I read this wrong but all i have to do is remove pin 2 and swap it with pin 3?
You need to move the ground for the CD changer.
Not being funny what gives you the right to tell me what i can or cant fit, ive asked for advise in order to rectify my cd changer fault thats all.
Relax, he's pulling your leg :)
You'll find that most people would give their left leg for what you have just installed.
Or, their rubbishy Stream unit :thumbup:
He was just teasing in an effort to get your quite rightly highly regarded Columbus from you in return for his seamingly meagre Stream unit ;)
Hi VRStu, the CD ground wire repinning worked a treat great my next problem im having is a phone kit which i also installed here are the part numbers I used OEM PHONE KIT 1Z0 035 729 - Interface Unit
8P0 035 503 E - Bluetooth Antenna, 3B0 035 711 B - Microphone the problem im having is the phone kit does not work gateway coding and telephone ECU coding is all correct and the telephone ECU communicates correctly via canbus. There remains a fault in memory in the telephone ECU "01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 249
Mileage: 19659 km
Time Indication: 0
Date: 2000.00.00
Time: 13:37:53
The fault remains permanent and possibly why the system does not function any ideas guys?
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 249
Mileage: 19659 km
Time Indication: 0
Date: 2000.00.00
Time: 13:37:53
Please post a full autoscan
