driveshaft seal replacement - major op or straightforward?
SWMBOs Octy went through MOT test yesterday - clean slate :thumbup:
But: signs of oil leak from gearbox and I suspect the seal where left driveshaft enters gearbox. Is replacement (driveshaft removal) a very complicated operation or more straightforward? Not that I will have a go myself, I'll leave it to my garage, but I would like to know if the hole in my wallet will be gigantic or just a big one :D
If it's still like VWs of old, it's fairly easy. Drain gearbox oil, Undo six bolts at the gearbox end, move driveshaft out of the way, unbold drive flange, replace, refill oil.
