Drivers door lock
Got to work this morning and went to lock the car with the remote but the drivers door wouldn't lock (the other doors locked fine). I then tried the key in the lock and that didn't lock it either. Finally I sat in the car and tried the button on the armrest that locks all the doors - no joy either.
My drivers door inside handle cable has broken and I'm having to open the window and use the outside handle to get out at the moment - I'm wondering if the problem is connected to that?
It's just really p***ing me off at the moment because the car has been comparatively trouble free for almost a year now and just as it goes out of the 12 month warranty I've got loads of things going wrong with it :mad:
Just remembered I disconnected the battery at the weekend, with the drivers door open, when I took the door card off. I also forgot to plug the controls in the armrest back in before I reconnected the battery. Don't know if these would have any effect on it?
Does anyone know if there is a reset procedure? If I disconnect the battery again with all the doors shut, then reconnect it and try and lock and unlock with the key in the door might that fix it?
Got to be worth a try.
Problem resolved - I sat in the car and pressed down on the knob on the door while locking it. Now locks and unlocks fine.
I have only myself to blame as a little ring shaped bit of plastic fell out of the door card when I took it off at the weekend and I thought it had come from underneath the bit where the locking knob pokes out, so I pushed it back onto there. This had made it too tight for the knob to move in and out (oo-er :P) so thats why it wasn't locking.
Now I just need to figure out where that little bit of plastic actually came from... :confused: hope its not important :o
glad you got it sorted out. You will always have spare parts when you start taking things apart :P
Glad your issue is sorted, I still have the driver door problem where interior light and door light not being triggered with door open. I got some spare micro switches from radio shack and now need a day to mess around with dismantling the locking mechanism and replacing the switch. Will post pics when done
I think a picture guide on how to re-solder one of those locking mechanisms would be really handy. Every few days someone on here seems to have a central locking problem :(
