octavia headlights
hello to all
1st post ever
i wonder if anyone could reccomend good replacement bulbs for the main and dipped bulbs on my 56 plate octavia elegance estate. also does anyone know the ( h )
numbers for the abve mentioned
kind regards graham
I have fitted phillips Xtreme to the dipped beams and am very happy with them
hope this helps (H7 i think) but the bulb sites normally have a model search which gives this info for the whole car
Welcome to the forum, lots of useful info and helpful people here.
If you try a search, I think you'll find a few threads which answer your questions about Octy headlight globes.
I like Philips X-treme, but they only make a H7 (lo beam ? ), not a H1(hi beam ?). Next best is Osram Night breaker. Some people find the +80 and +90 globes don't last as well as the standard globes. Fleabay is often the cheapest source (unless your local motor spares supplier is having a special deal).
I've recently fitted H7 Osram Silverstar 50% bulbs and find them a massive improvement over the stock bulbs. £17, happy with that.
Stock ones were shocking - mind you I found the previous owner had a blue bulb in one side and a different make in the other side.
Nightbreakers for me! Main beam only as I have xenons but big improvement over standard bulb.
Welcome to the forum.
