Snapped breather pipe??
Ive just fitted a new n249 valve and while fitting it i snapped the breather pipe which is fastened to the metal bracket above the n249 valve,ive taped it up at the minute and theres no problem with the car,does anybody no if you can get coloured breather hose's or should i just order a genuine part:confused:
you can get Silicone hose but not in the moulded shapes. I believe it is ID 8mm but make sure to get at least 3mm wall and good clips. if its the bigger Y shaped one and the one that goes down to the Crank case breather then there is a silicone version available freom Eurojet racing in the states
Cheers karl,its not the crank breather its the other 1,ill take a look at eurojet,thanks again:thumbup:
Do you mean the ribbed plastic pipe that feeds air from the airbox to the secondary air pump?
Looks pretty easy to replace if it is that. Skoda only part from what I know.
