Slight vibration problem
Does this sound like an engine mount? I was cruising at around 60ish fine no probs but when i was accelerating to 80 there is a slight vibration. Once cruising at 80 vibration gone but soon as you floor it its back! Any ideas?:confused:
What gear were you in and what RPM???
in 5th around about 2500-3000 ish
I think that could be your problem. These cars are fitted with a dual mass flywheel which will rattle its *** off if your in too high a gear. Although you have the torque there, the flywheel can't handle it, hence the vibration. I would say don't floor it in fifth until 3-3.5k as a general rule.
Drop it back too fourth next time then boot it.
i'll try that later thanks:thumbup:
I had the same problem with mine turned out to be a worn wish bone bushes replaced both for £60.
Problem solved
