Wet rear nearside footwell
Before I take the car to a dealer, is there a known fault that can cause water in the n/s/r foot well?
No obvious signs of a (rusty) hole - floor, from underneath, looks good.
Can rear washer pipe fracture and leak inside car to here? (It's been replaced, about a year ago.)
One thing I can't stand in a car is wet inside, so any ideas?
Edit: just looked at rear washer pipe & water pours out and runs down inside wheelarch. Trouble is the leak is not accessible!
Edited by Richard Baguley
known issues of water leaks through the inner door panel seals , do a forum search , you will find all the info you require
Have you looked under the trim which runs along side the rear nearside seat by the door? Theres a connection for it in there which i assume has popped off if your footwells wet.
I think theres one small plastic screw, and then it just unclips. Should be a 2 minute job.
If you rear washer jet still works it must be something else such as ancillaries carrier!
check your door seal. I had to reseal the panels on both rear doors. There's a "how to" on here somewhere. Takes about 1 hr per door.
Had mine done on warranty..........
ive got a similar problem with my passenger footwell has got some water leaking onto it when there is heavy rain, i found it was coming through the vent for the heaters and through a small hole that just built up.
