Front parking sensors
How do these work? It appears that the units themselves are identical to the rear parking sensors but where does the wiring connect into the car? My car is an elegance model currently without front parking sensors but will it have a wiring connector somewhere to plug the loom for the sensors into?
yes i believe so
Can this kit be linked into the radio display on the elegance, like the rear sensors????
Doubt it as even factory fit front sensors do not display on the radio, they have a seperate switch to activate them and you just get increasing beeps as you get closer
I have front parking sensors factory fit and they display on the Radio. They are activated when you go into reverse, plus there is a switch on the lower dash above the ash tray.
Non factory fitted front parking sensors DO NOT appear on the display. They do have a different beep to that emitted by the rear sensors, and have an off switch as well.
