Transponder programming (keys)
I am having problems getting a new un-programmed transponder programmed in SWMBO Golf MK5.
I have a working SKC (cheers :thumbup:) but the new transponder doesn't want to match to the car.
Now according to the measuring blocks, (on the new transponder)
1. "key status (transponder lock)" is NO, so the transponder is indeed new and has not been coded before, correct?
But the
2. "engine start permitted"
3. "variable code authorized"
4. "fixed code authorized"
are all also NO, whereas on the current key / transponder (which is working fine) these are all YES.
So am i doing something wrong (i followed these Immobilizer IV Key Matching Instructions)
or is the transponder the wrong one for the MK5 Golf? (the seller lists it as suitable)
(I have tried this on both VCDS 805.3 & Beta 812)
27683.attach
27684.attach
Edited by Gizmo68
is this a secondhand key from ebay.
If the golf is the same as the octy2 then keys that have been used on another car cannot be programmed to another ecu. Only new unused keys can be programmed.
It is from eBay, but it has a brand new un-programmed transponder in, so effectively it is a new key.
probably you have there transporder III. gen it looks same like IV. gen. or you have keys from Skoda/Seat, immo IV. gen. supported just same mark of producer, the key from Skoda doesnt work in WV.
The seller is listing them as purely VW transponders, to fit the MK5 as well as a Scirocco (plus lots of others).
I think you may be right in it being a III. gen though.
There was a batch of theoretically compatible transponders on the market which showed the same problems like you described them. Sounds like incompatible ones after all...
write here part number according to U/we can find how it is compatible
Cheers Sebastian, that is what i thought.
Yes, i had their details, waiting to call them tomorrow.
No part No.s are visible on the transponder, the seller has agreed to a full refund, but i just wanted to make sure i was doing nothing wrong before i returned it.
Update on this,
I bought another new blade & transponder from Hickleys (AKTP2) which arrived yesterday, got the new blade cut, but I'm still having the same issues.
Now with my current (fully working key) under channel 01 (25 Immobilizer, Adaption) the stored value is always 1,
I change it to 2 then save, done, Go back, etc (as per the Ross Tech Instructions) the second key sometimes then appears to code - the car will start, BUT the immobilizer light on the dash flashes away!, (the current key/remote is placed behind the passenger seat on the floor whilst I am doing this, maybe the current transponder is still in range??)
When I try to start the car a second time the immobilizer cuts in and stalls the engine once it has started. Proving the key is not programmed.
If I then go back to channel 01 (with the new key in the ignition) it comes up with "ERROR Channel 01 Not Available", If I try with the current key the stored value is 1 again.
I have also tried programmed zero keys - and neither key started the car. :thumbup:
If i then program the current key it works again (proving I'm doing something right!) :rolleyes:
There are no fault codes with the current key, but the new key displays the following faults:
Wednesday,18,March,2009,14:13:11:22041
VCDS Version: Beta 812.4
Data version: 20090214
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ4W08**** Mileage:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 B HW: 028 101 147 8
Component: R4 1,9L EDC G000SG 5645
Revision: 12345678 Serial number: VWZ7Z0D9253489
Coding: 0000071
Shop #: WSC 00000 028 00001
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - - MIL ON
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 0.0
Readiness: 0 0 1 1 1
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Part No: 1K0 920 950 L
Component: IMMO 3554
Shop #: WSC 00000 000 00000
2 Faults Found:
01176 - Key
008 - Implausible Signal
01179 - Incorrect Key Programming
000 - -
End ---------------------------------------------------------------------
re the 01176, - The battery in the new remote is showing 3.1V (rated at 3V new)
I am also in e-mail correspondence with Andy at Ross Tech, but as of yet we have not found the problem.
I forgot to say that i have even tried:
Current transponder
New Key blade
New remote
It then all works as it should :rolleyes:
So it is definitely transponder related, either i am not programming it correctly (if that was the case then surely i wouldn't of been able to program zero keys - no key worked, then back to 1 key - it worked correctly again would i?)
But why am i getting "ERROR Channel 01 Not Available" with the new transponder? is it another non compatable transponder?
I spoke to Hickleys before i ordered it and they assured me it was the correct transponder for my car. :confused:
It turns out hickleys have supplied the wrong transponder (they supplied one for a non CAN based car!)
The correct one is in the post - although it costs 5 times as much than the non CAN based ones.
Hopefully it will be 3rd time lucky. If any one with a non CAN based car requres a transponder look in the items for sale
All sorted and took less than 5 mins to do from start to finish (although i was becoming an expert on how to do it!) at least it's pleasing to know i wasn't doing anything wrong. ;)
  • 4 months later...
OK, what is a CAN car?
Just bought 2 of these for a 2002 n a 51 Fab Tdi Estate:
AKTP2
• VW - Audi - Seat - Skoda 1998 Models On
• AD100/MVP Programmable
CAN based is the new Fabia, Octavia & Superb.
A 2002 Fabia is non CAN based so the AKTP2 should be the correct one for your car.
