car veers to right when accelerating
My Laurin & Klement veers to the right when accelerating and to the left when decelerating- could this be a steering geometry problem or is it the wheel alignment (I understand it's all 4 wheels that have to be aligned ) The front tyres are new( and ballanced) and all tyres are the correct pressure.
Has it always done it?
I know this might sound weird but some FWD turbo cars suffer from torque steer when acclerating and pull to the right (such as the Maestro/Montego turbo of past years :rofl:) having said that mine doesn,t do it so could be worth checking geometry :thumbup:
It could be a tyre problem. Try swapping the front wheels over and see if it makes a difference. I had a similar problem with a Citroen a few years ago and the problem moved to the other side when I swapped the tyres. I couldn't convince the tyre dealer there was a problem because the tyre looked OK, all he did was move the wheel to the back :-(.
D
try steering slightly to the left to compensate :rolleyes:
Couldn't resist. If it were me, I'd get it on a 4 wheel alignment rig....
Thanks scoobynut - probably the cheapest way to go first.
Sounds more like a knackered bush to me....
  • 2 months later...
i have the same issue car will suddenly veer to one side when accelerating and same again decellerating.
its not apparant all the time , its a sudden occurance of a torque steer effect .. that will considerable cause the body to want to goto the left whether gentle or hard acceleraion is applied. Particulary around 40-50mph. Its like a feeling the one wheel puts down more traction and pulls the car over..
still continues after
front tyres swapped .
Wishbone - Bushes done.
tracking rods replaced
4 tracking/alignment
what else am i looking at that will cause this ..
It's not something to do with the road surface is it - if it's intermittent it could be crud or whitelines.
If it's intermittent, I'd be more suspicious of something other than the car.
Could be the nut behind the wheel of course :rolleyes:
D
Have you had a balance & geometry check?
And bearing noises? Al roads, or certain ones? Adverse camber on these roads?
