Clock Time Auto Set
Hi,
When I fitted the cruise control, I had to disconnect the battery. When it was re-connected, as well as losing the trip memory, the clock was also wrong so I set it manually. The radio is an RDS model, and I can display the time I set in the radio display. With other RDS radios, I have never needed to set the clock, the radio gets the time from the RDS signal and sets the clock. I've been through the manual but can't find any info regarding this with the Octavia. Does anybody know if it's possible for the clock to be set from the radio signal ?
TTFN
D
Not possible, it needs to be set manually.
The oem headunit does not have a clock in it at all. The clock you see on the display is sent to the headunit over the cars canbus from the dashpod. If you set the clock on the dash, then the radio will display the correct time.
