coilovers or anti-roll bar set up????????
been looking at a lot of threads recently on coilovers ,suspension and even started one myself!i know i will loose some comfort with a coilover set up and if i go that way i will get a half decent kit!
however i have a little one on the way in summer and this is also my family/daily car so dont wanna bump the kid all over the place!
question is i want better handling for next months track day so do i get the coilovers or a anti-roll bar set up to get better handling?
i know the coils will prob be better for handling but if i can get better handling over standard with ARB's and not loose too much comfort this may be a better deal for me!!
help needed before i spend a wad and need done within a month??
ps its not my intention to do much track action at all,so just occasional blast on the roads!!
If i was you i would go for the following
Powerflex dogbone mount
S3 lower brace
Neuspeed 28mm rear arb
These will make a big improvement to the handing and powerflex bush will help get rid of 'wheel hop'.
The above will cost around £300 and will be a great start and you see a benefit on the track.
If your still after more after fitting these then i would go for the Koni FSD's & H&R set up.
Post your location as there may be someone local to give you a demo of this set up.
or just buy my KW V2's in the for sale section.
Adding a RARB is an improvement over standard but until you loose the standard shocks which are the archilles heel of the octi you will always be left wanting more.
If I had it to do again I would go for the Weitec coilovers however I am very happy with my current set up. In hindsight though the Weitecs would have been cheaper.
what are they weitecs like for comfort/handling??
also post code is wr5 3tf worcester if anyone has a good set up to show me???
