Footwell lights
I finally got around to doing the driver's side this weekend.
Haven't worked out where I'm going to mount the passenger side ones yet.
More details here:
Rob's Skoda vRS
Great stuff, like it. What bulbs did you use?
Would I be right in saying you took a feed from the interior light? I put a small strip on each of the rear c pillars so the Mrs could see easier in the winter months when putting the little'n in her seat.
She wants them out as apparently Blackpool is a tacky look! Wish I thought of the footwell lights sooner!
I used 5mm white LEDs. I took the feed from the wiring to the courtesy light in the door as I only wanted the lights to come on when the door is opened :)
Good work Rob. Now you'll have to make sure you keep you carpet clean or its really going to show up ;)
