0 - 60 times (remapped vrs)
Putting the power down is the hard bit in the first couple of gears, 3rd it starts to be just about possible in the dry. The Quaife helped loads though as when it is borderline it will just transfer the power enough to avoid the slip you'd get without it.
  • Replies 63
  • Views 28.8k
So stage 2 mods.. below 6 seconds? :P
Alot class it as Stage 3.
Stages pfffft. They mean nothing. I've got the "Stage 2" Turbo good for 240bhp, so duno where you get stage 3 from haha
7. odd seconds to 60mph with a map, 8.5 or so standard?
Sub 6's with a few choice mods ;)
Choice being a new ratio gearbox to reduce need to change to 3rd for 60? LSD? 4x4 (:)) and loads more than the usual generic map ******.
It would cost £000's to get a Fabia under 6 seconds. and then it begs the question - why bother?
A remapped one (which realsitically wont be as much as some think, so about 160-165BHP max) will hit 60 in about 7.5s, as opposed to standard 8-8.5s
Im not sure what Stage 2 turbo you have thats good for 240hp, as if its the TD, its good for 260hp actually.
However the stage of turbo has nothing to do with the stage of the CAR.
Terms:
Stage I usually refers to a chip upgrade or nozzles only.
Stage II usually refers to chip AND nozzles.
Stage III usually refers to hybred or non-stock turbo, nozzles and chip. .
Stolen from TDiClub forums
So as I said before pfffft and haha. Most would class a sub 6 second 0-60 time made by a stage 3 tune.
Im sure all the above would get you a sub 6 second 0-60 time. However a mere 230bhp, some decent tyres and a good driver should be able to run below 6 seconds with the helps of a A.T.B diff.
Im not saying a simple remap to 170bhp will get you below 6 seconds?
As for costs, if you wanted it just for straight line speed, then not that much, slicks, big turbo, exhaust.... and new clutch after uve burnt it out trying to launch it!
As for why? Why bother getting a car than can do sub 6 seconds full stop? Why bother using a car? Tha question is just silly.
my car goes from 0-60 in 3 seconds..........
if you count reeeeeeeeeeeeeeeeeeeeeeeeally slow
i love these threads! lol. wish there was more of um. on a good day with my upgrtaded clutch i think 6.5 to 60 is totally posible
How does an uprated clutch help?
People are living in cloud cukoo land...
Its a shopping car with a few choice aesthetic mods and a little extra power.
I've yet to get better than 6.3 seconds, on proper timing gear, and mine is more than just remapped. I think unless you have really sticky tyres & a sticky surface, sub 6 seconds is unlikely due to traction and would be hell of an achievement in a fwd derv. :)
3 seconds........just count slower.....pffft
T. Spark IIRC actually has a ticket from a track stating 5.....somthing seconds, was deffo sub 6 tho
Unless you know the speedo error for your car - for mine 60 indicated is only 56 true - any 0-60 times are likely to be significantly over-optimistic. JMTPW.
Are you being serious? Are you actually asking how a uprated clutch can help get lower 0-60 times on a car? Or just being silly?
Thanks mate :thumbup: I have to admit I was impressed with the car, and myself too :rofl:
I am also a numpty driver :D so to get 6.3 for me is good. And that was GPS based on this racelogic thing so at least I know was pretty darn accurate compared to a speedo vs stopwatch. :rofl:
6.3 is a good time, esp. when you take into account the extra weight you have tbh over me fella.
My point was it is -do-able with the right conditions to these none believes, and more importantly to the idiots that say why? Well why do anything to a car, ever then!?
you saying hes fat? bit harsh LOL
Terms:
Wow so I'll go time my car when I get home and I should be sub 6 seconds eh, dont talk rubbish!!!!
TD (Thats turbo dynamics) state good for 240 actually or do you test them everyday or summert, god you must have a chip on your shoulder about our Skoda's
Can you ACTUALLY read "SEAT" boy? Note the difference between the 4 and the 6? :thumbup:
Stage 2 – MD376
Hi flow GT20 spec compressor wheel, cnc machined compressor housing, 360 degree
thrust bearing, cut back turbine blades, lightening of turbine wheel for faster ‘spool up’,
modified V.N.T. turbine housing, uprated turbine seals. Other ‘blueprinting’
modifications. APPROX 220-240 BHP
Our price £1030inc
Don't forget that shifty's fabia only made a time of 5.85 seconds 0-60 and consider all the weight he had stripped out.
I would say that you would do well to get a sub 0-60 time with a full interior
30-80 times are a different story however ;)
LOL well...
My friend has a Stage 2 turbo on his and to 60 theres not a bean in it... its after that 60 + it shows...
LOCK THE THREAD PLEASE :D
up graded clutch =more torque from map!
only if its mapped that way :)
Due to the need to change gear quickly, the 0-60 figures on a diesel are hard to replicate
In gear performance of a remapped diesel vRS will blow many petrol cars away..thats how you should measure it IMO
because thats what suits you better?
its only ever diesel drivers that go on, and on, and on, and on, and on, and on, and on, and on, and on, and on, and on, and on, and on, and on, and on, and on, about in gear times because everyone else can change gear :)
why shout about being faster than a lambo when both in top at 15mph or whatever when if driven properly the lambo will destroy you, only to win the arguement.
The torque at the wheels + actual power output of the engine makes the difference. Petrols have shorter gearing to be able to use the nice big power band. A properly sorted petrol 1.8T will destroy a properly sorted 1.9 PD - no questions asked.
The really big problem with derv in the lower gears in particular is that the power just cannot be put down. Bengie's 4x4 (Octy) has much higher transmission losses than a stock Fabia vRS, however he can/could launch with 4 wheels spinning but pretty much have traction mostly apart from that. Even more so in the wet.
The Quaife helps.
Lowering weight helps.
Having a good smooth map helps.
Having a lambo would be a fairly large advantage too :rofl:
Guest
