Rear windscreen wiper clip
Does anyone have an idea where I can find the adapter/clip for the rear windscreen wiper? Its the clip that holds the wiper onto the arm, if your wondering what Im talking about :o
its part of the actual arm isn't it , i don't have a standard arm fitted so can't check
Im sure the blade just clips in to the arm.
Thats the thing, theres nothing for the blade to clip into...if you were to lift the arm you could just pull the blade out with little effort.:confused:
arm required then , upgrade to the Polo one , then you can have a flat aero blade
  • 2 years later...
does anyone know where i can get the clips from or is it a dealer jobby
the clip is part of the arm ie moulded into it. Youll need a new arm as its broken and cant be fixed.
