Tyre choice ?
Eagle Ventura ..... or ....... Bridgestone Potenza
On standard Fabia VRS wheels. 205/45 r16.
Handling in the wet a must.
Need to change v.soon.
Of the 2 you mention, the RE720 Bridgestones offer better wet & dry braking and grip. Also, slightly cheaper at
  • Administrators
re the Nero's...not quite on them, but p-zero assemtrico...will post a pic later of the fronts which I have not rotated since January. They have done two track days, the handling day and nearly 10k miles.
Needless to say the fronts look buggered, but there is actually a good depth of tread left.
Wet, Dry grip is great, cornering is very enjoyable.
Nero's next...maybe soon owing to the fronts wear...
Rear right still has the little spikey bits on the shoulders. The fronts are smooth all round. Hence I should change them really.
