Octavia vRS Fuel Consumption
a couple hours out with me and ill have you getting 10% more :thumbup:
Well on a recent trip of 60 miles i decided to reset both readings on the Maxidot and the trip reset.
Great results Carl - especially with yours running a little more than normal :thumbup:
What correction factor did you end up using when adjusting the trip comp accuracy?
Steve
Hello all
I normaly get around 9.6-10.6 l/100km around town depending on how much I use the power without hammering it. Driving here in Canberra is pretty easy - plenty of main road, some freeway, light traffic.
For interests sake, I thought I would see how much I could improve that figure by changing my driving habits. So for the last few days, have been driving like a granny. Actually, not a granny, but like an economy run specialist. Minimum revs,smallest throttle opening, tallest gear possible while keeping up with traffic. Maintain momentum at all times and bypass gears (ie1-3-5-6) and keep revs between 1500-2500. My figure improved to around 8.7 l/100kms. Shows what can be done.
But it's deathly boring and hard work. So i am off out to wring its neck, have a fang and put the smile back on my face. That's why I bought it.
cheers
powerd
2.0CR TDi - 8000 miles and an average of 49.1 mpg showing on average 2. Checked against fill to brims and is within 5% accurate
Steve
IIRC I had to change it to 109 to make it accurate to the figures I was getting using fuel receipts.
It may still be out but I can get 620 miles from one tank and that is outstanding for a car with 300lb/ft of torque :D
Will all end when I get KO4 though :rolleyes:
Carl :thumbup:
How? Your mpg sig is still only showing 36.5mpg, and reports on here are showing higher with the less efficient TFSI :confused:
I'd be delighted to see anything beginning with a 3 in it ! my computer only seems to know how to display 25.0 or 26.0...I don't drive like a loon...& don't carry much (not even passengers !)...ok I only do a 12 - 15 mile round trip most days..half dual c/way & half town - stop/start...but I did expect better...not sure what my best on a long trip is...maybe mid 30's on cruise.
Yesterday I tested on a long journey and managed high 40s to low 50s in MPG from wirral to birmingham, I think thats good for a petrol turbo. But it was soooo boring. 50-60mph, low revs, freewheeling down hills, etc. Even miss daisy would have said 'dang this is boring!'
On the way back I only managed 36-38mpg, I wanted a bit more enjoyment lol.
Maybe my computer is just too generous :smirk:
Mater,
What's the display in the top LH corner? Never seen it on my Maxidot
It's the compass from his columbus sat nav.
