Boot lid not flush, can it be adjusted?
Ive just noticed that the boot lid is not flush with the lights on the drivers side. It sticks out (not up) 3-4mm as opposed to the passenger side which is fine. Theres no obvious damage to the car and it closes and opens fine with no rubbing or scraping noises that I can hear. I was just wondering what would have caused it and if it was adjustable?:confused:
On my fabia there's a couple of rubber stoppers you can twist to adjust the position it sits in. Might be the same on yours. Just on the underside of the bootlid in each corner. :)
Theres a small domed rubber stopper which didnt seem to be adjustable, and 2 small rubber 'plates', one on the boot lid, one on the car body. They seem to be adjustable and might do the trick but are torx style bolts, so ill have to hunt my set out to see if it does anything ;)
Thanks for the info and pointers :D
Stupid but is the lens stitting correctly?
Yeah, I would think that's more likely the problem.
