rear brakes
just abpout to do the rear brake discs and pads but do you have to do the bearings at the same time?ie are they already bed into the disc itself?
cheers
No need to do the bearings, they are part of the hub assembly. The disks attach to the hub but no need to remove the hub at all.
cool cheers lex
Just remember to have a Piston rewind tool to hand before you start to take things apart....
No need for the bearings, You can do the discs on their own but make sure the pistons are pushed backwards ans check for dust seal damage.
cheers
