Error codes Fabia vrs
I am getting two recuring error codes on my Fabia vrs.
19557 and 19558. No other symptoms at all, only the engine warning light on the dash. I have checked the wiring loom under the bonnet and checked the wiring connectors to the EGR valve and the MAF sensor, all appears to be OK. The car is 2 months out of warrantee but had the EGR valve replaced about 6 months ago because of a leak found at service, the car has not shown any other problems. I wonder If any one else has had this problem or can offer advice on how I should proceed.
Regards, Stonepoint....
19558 - Motor for Intake Manifold Flap (V157): No Signal
19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
If codes cleared and they don't come back, due to EGR being disconnected at some point. Otherwise EGR or Vacuum control defective.
Took car to local dealer, Meadens of Sway in the New forest. Fault was diagnosed as a broken wire to the the air flap motor ?. 1/2 an hours labour and £5 for parts. Fault is now sorted thanks for useful coms from you guys.
