Help - passenger foot well water leaking
HI,
I have a 2000 fabia.Recently I found the foot well of the front passenger got water leaking when raining. It never happned before. Could anyone suggest the reason for that, please?
Many thanks.:confused:
plenty of stuff on here , you just need to do a search
pollen filter housing , usually due to the bulkhead drain holes being filled by debris
door panel leaks , very common on the Fabia
Thanks. The water actually comes from the front (under the small storage space on the passenger side) not the door. I can even see it coming in.
Edited by gordon_y66
Plenum chamber below windscreen will need cleaning out.
any help regarding how, where, what, etc
cheers
I think in the passenger footwell (looking up at the buttom of the dashboard) there is a chamber thing that allows you to get to the pollen filter. (Should be two sliders around a rectangle.) I think it can be accessed from there, although I could be on about something totally different/wrong!
cheers
It's under the black trim below the outside of the windscreen.
