Fog lights - how to change bulbs?
Can anyone explain how to get to the fog light bulbs in case they need to be replaced.
If you look at this picture you can see the plastic towing eye cover removed, behind it there are what appear to be two Torx screws that hold the fitting in place.
I am guessing you undo these and pull the light fitting in the inboard direction to remove it.
This was useful, thanks!
I was always afraid to physically remove the lens incase it would not sit back correctly.
Wuld be interested to hear how you get on.
I replaced fog light bulbs with no problems whatsoever. They are sitting nicely on their place.
You just can't do it wrong.
