Sticking Door Locks
Two of my doors, one front and one back, have locks that don't always open or close when using the remote. I thought the rear door was caused by me when I took inside off to seal and stop water leak.
Is there somewhere I should WD40 or have I got to take inside off again? Anyone had this and fixed it?
I've had a lock replaced under warranty, passenger side rear deadlocks and then will not unlock........Common problem I believe as my local Stealer has replaced quite a few
This is the pop-up bit which seems to stick. I don't think it the lock itself (i.e. not where you would put a key in)
What trim level is it??.........Our's don't have any pop up thingies (Fabia 2 Blueline )
Am I in wrong forum? My Fabia is 2003 comfort trim. Is 2003 Fabia I not II?
