New to the car, not to the wrench...
So I have a quick question for yall:
How far will a bentley passat B5 manual get me for working on this car?
If you have a better source of info on it, please let me know as I do all my own wrenching. Especially here in the UAE since I don't trust ANY mechanics here to do anything but kill the car or screw it up royally.
There is a dealer with a good rep though here, BUT its over 3 hr drive with traffic for me to get to them.
So any good advice for the do it your selfers here?
Better yet any good torrent links for a proper skoda service manual?
Or am I stuck piecing together Audi and VW tech manuals for this car?
Oh, and on a random note Hello all I am new to this car and forum.
When the dealer check is complete tomorrow and I finish the paperwork I will be the proud owner of a blue Skoda superb 2005 model with from what I can tell full options including fridge in trunk.....IE BAR CAR......(for the passengers obviously)
-Bill
The manual is available as a download on here, type into the search window, and what is a Bentley B5?
2005, = out of warranty, so save yourself, filters are easy and anything more an indy will do for 50% less, the car isn't science, it's a typical mid 90's technology and they only have minor faults like CV joints and gaitors and the odd sensor that goes wrong.
Superbia,
Bentley is the manufacturer of the greatest automotive manuals known to mankind and for any VAG group product I have ever owned the first thing I purchase after the car and insurance.
Passat B5 is the platform what I can tell goggling the car that skoda shares quite a few things from including general style not to mention engine selection.
I really don't think you understand how awful the mechanics here are. There are good ones out there, but even the independent shops charge what I consider to be an excessive rate per hour for labor and I have found only one half way decent mechanic in this town so far and he only deals with BMW and Mercedes, no VAG cars.
If they break something, and they do so quite regularly, its your job to pay for the new part and for their labor to fix what they broke.
Furthermore its YOUR job to provide them with the correct part. You take your car there, they make an attempt to diagnosis the car, tell you to go and get them this part and you go get it. They put it back on the car and put it all back together, realize they replaced a perfectly good part, then the process repeats.
I am by profession a Aviation mechanic, before that I was a Auto diesel tech.
I will give you a proper example as this just happened to me a hour or so ago.
I took my family car into the ac service shop to add a little r134a to the truck as some has leaked out (all modern cars suffer from this problem using r134a). Well to fill to proper pressure its 30-35psi max (dependent upon temp etc) on the low side(weight of the charge not withstanding) When he filled it and walked off I glanced at his gauge and it read over 70 psi. This a very bad thing since i like my AC system and my car. So after bringing pressure back down to normal, guess what? Now I have a blockage in the system, no refrigerant flow and its 46C outside and I drive a black truck.... 2 water stops later I made it home to type this out.
Luckily it is still under warranty for the hoses, compressor and the rest of the system, basically everything but gas levels are considered normal wear and tear in this country under its terms.
The dealership will be fixing it under warranty now, but had it been out of warranty I would have been looking at around 1400 usd to repair it.
Here is a link to a fairly good AC manual if your curious and want to learn more. It covers all the basics quite thoroughly.
Troubleshooting with Gauges FAQ
Thank you for the help auroan and superbia for pointing me to the manuals!
-Bill
From what you just said I'd do most of it myself bud, the filters are simple to replace, all of them, as long as you have a manual to point you around the various sensors I think you should be ok, even the cv issue isn't hard to do as long as that dam bolt isn't rusted in.
So Bentley manual is equivalent to a Haynes Manual over here.
Not exactly, check the price out, this is a publication by a USA manual provider due to the fact that VAG and other foreign car manufacturers don't care to rewrite the factory repair manuals in a way that avoids any possibility of being sued in USA courts - oh and it will be in a different kind of english! In other words it what has been provided for the VAG etc agents in USA - so its a lot more than a Haynes equivalent. I once bought "access" to a Passat B5 from fleabay, the only thing was it looked quite good but I had no immediate use for it as car was still too new, later when I needed it my access to the Bentley link had been removed - ah well that's fleabay for you - pay peanuts etc!
