Dripping fuel at the moment
Just a quick question. Seeing as it isn't a good thing for a car to be dripping fuel, I was after a quick answer to what's under the offside rear footwell in terms of fuel? Is it the filter, pump or something else? A reasonably quick response would be appreciated folks.;)
Fuel filter is around there.
Fingers crossed then. Is it a simple job to change to a new one?
If that's where the filter is, the lines must be there too; take a look before buying a new filter.
Would they be perished or need replacing when the car is only an 06 plate?
The fuel filter & fuel lines are in that area,have you run over somthing in the road or grounded the car out on rough ground at all? you may of caught the fuel lines & damaged them,ive had fuel filters corrode & leak,has it ever been changed? the fuel lines are plastic so cant rust,hopefully its just a rusty or split fuel filter that can easily be replaced,either way it needs fixing asap:thumbup:
Aside from what Mikey says (all possible), I was thinking about a joint not being properly sealed or remade if the filter's been replaced.
:iagree:has the filter been replaced recently?
Update : Thanks for all the replies folks. :thumbup:
I called Skoda Assistance and they fixed it for five pounds (new filter). Hopefully this is the end of it as the smell of fuel has gone. Good job really as I couldn't afford to loose too much V-Power!
As for the question about whether the filter had been damaged or replaced, it was the original and there was a tiny hole in the casing. It looked as though a stone could have pierced it.
Panic over and now my daughters can be transported in relative safety again.:rolleyes:
p.s. It took about three hours for them to turn up - good job I was at home...
