a distinct smell of wee
put my air con on in the car a few days ago, now everytime the fans are blowing cold air it smells distinctly of p!ss, i know aircons that havent been used have an unpleasent smell, usually foisty smell, but this is seriously bad, i thought my nephew had weed in his car seat in the back its that distinct
what can it be?
it will be bacteria inside the bottom of the heater assembly in the car , get done to halfrauds , they should have some aircon deodorizers in stock
or someone or a cat has pee'd on your car
It also helps if your pollen filter is relatively new. My aircon had a delightful vomit-esque smell to it which went after the manky pollen filter was changed.
You want the Comma air con disinfectant 'bomb': Comma Aircon Cleaner from Halfords Price £11.73 Free Comma Air Con Cleaner When You Buy Measure and Charge Air Con Top-Up Set the air con to full whack on recirc, press the lid down, stuff it in a footwell and retire to a safe distance but too safe where someone can jump in and nick your car while the engine is running :D
Run the fan on full blast and squirt some Dettox, or similar antibacterial cleaner in the air intakes.
Phil
