how much screenwash ?
if the windscreen wash bottle is empty, how much windscreen wash do i put in ?
thanks
I use almost the same tactic, but i look, and slow down as it comes up the filler neck, so i dont lose any. Bit tight me.
Matt
ha ha ha
you guys kill me !!
Winter use it neat, i jus use cheap stuff for that. Summer i water it down, and use lemon smelling one, about 50/50 :D
I don't know about the Fabia II but my Furby vRS (without head light washers) uses exactly 2 litres when completely empty, however I normally fill it up when the warning light comes on as the beep is annoying.
I normally use the Halfords stuff, I've got a 5 litre undiluted bottle of it. I have used the double concentrated fluid from Halfords in the past.
i just top up with a little as i hardly ever have to use it. i just clean the windows by hand and save a little weight.
Have you noticed any increase in your acceleration or fuel consumption since using less screenwash?;)
IIRC 2.5 litres
IIRC 2.5 litres
thanks
Hey a fellow Bradfordian... only just noticed! :thumbup:
What did you mean then? What level of concentrate mix to use?
yes,how much water and screenwash.cause
If you have headlight washer sistem 4,5L but if you dont 2L
I know this is going to sound really banal but you need to be careful on what washer fluid you use.
The fan jets used can be a little sensitive to clogging in certain conditons with certain fluids so it's advisable only to use VW approved fluid. If you don't and the system fails, you might not have a warranty.
Just advice spilling over from a few previous threads.
This is very dependent on the make of screenwash used. Some are for summer 20:1 (100ml to 2 litres of water) some are 10:1 or 9:1 (100ml added to 1 litre water). I don't know the amount for OEM Skoda stuff. Have a look on the back of the bottle to find out the correct ratio for summer and/or winter use.
VW one for summer you can get away with a few caps (100-250ml) in a 5L tank although obviously you need to go stronger than this for winter use.
actually 2 litres of water does weigh quite a lot. every single gramme counts.
What 2kg for 2L of distilled water? Oh noes.
I think you're better off taking a dump before you drive ;):D
:+1: :D
Back to the original question, I use it at about 10:1 in the summer. So you don't need an awful lot in a normal 2L tank.
Steve
I just use halfords ready mixed stuff. Says VW compliant on the bottle.
