To vag-commers: revving while braking
Hi all,
is it possible to act with vag-com in order to disable the nasty ECU feature which cuts fuel to engine while applying brakes?
TIA,
Hi all,
TIA,
Why would you want to do that ? you don't need fuel while braking !
Radiotwo
Ah, ah,
I like fuel cut off when releasing throttle but, if I need, for example I want to match engine rpms while gearing down and breaking.
never heard of left foot braking?
impossible in the vRS unfortunatly
If you are on the throttle and press the brake pedal it cuts the throttle, but if you are on the brakes and then press the throttle it revs up , Lummox posted this originally , I tried it and it works on my mk1 , worth a try
hth
Dave
hth
Dave
I couldn't read before coming back home. Will for sure give a try and let you know,
meanwhile thank you!
