Wiper Problems
Ok my wipers work for the first 10 mins or so of the journey, then dont after that, occasionally they start working again.
Or if they are on the Constant setting they will stay on, but if i then turn them off they wont go back on.
So far i have replaced the Wiper Motor, the wiper stalk and the Convience Control Unit and it hasn't made a difference.
Its not a VRS so dosn't have a alarm so dosn't have the bonnet pin sensor.
Any ideas?
X contact relay. Poor fuse box contacts for fuses F32 F41 and F15
Can you explain in a little more detail please
s
Maybe check the manual for the fuse box layout diagram, then invert it (pretty sure the manual has everything in for left hand drive cars!) and try removing the fuses moggytech recommends and make sure they have clean contacts?
Or I guess it could be the relay as also suggested which I have no idea about :D
