Wool mitt failed :(
I purchased a wool mint from elite car care about 3 months ago and so far used it about 4 times. After every use I normally pop it in the machine and give it a good wash before leaving it to dry.
Last night I came to use it only to find it molting :( I only noticed after half my Fabia was covered in strands. Is this the normal life span of a wool mitt or would machine washing have ruined it?
TBH you should washing machine it, just a good rinse after and hanging it to dry.
I had the same problem, mine fell apart also?!? not sure if i will replace it yet?
Machine wash gently, without soap etc
Mine died when I washed it a higher temperature - I'd forgotten to turn the machine back down after doing a "white wash" at 60-70 degrees!
I think I killed another one after putting it in the tumble dryer.
Don't machine wash them. Simple.
I use 6 synthetic ones, and they say machine wash at 40C on the pack, and they've been fine for 6 months, but I have now worn a hole in one. I wash them every time I use them and they seem fine with being machine washed.
I reckon each one has probably done 1/3 of a car twice a week, so that's probably two years use for most folks.
If it's a genuine Lambswool Wash Mitt then I just wash them by hand in the sink, the washing machine will, I am afraid, tear them to bits.............:o
I never have any problems machine washing the ones I have, genuine lambswool ones, at 40deg with a small amount of non-bio powder. Eventually they do fail, sure, but I've only recently binned the first ever Meguiars wool washmitt I got in 2003!
It's either varying water softness/hardness, water temperature or the power/cleaning agent people use that seems to kill stuff like this; but I can't work out which! Same goes for people having issues with efficiency of drying towels and the like. Very strange.
Steve
Drying towels:
Cool wash with a non bio detergent and absolutely no fabric conditioner, So don't use Bold!
Very true Mike, very true :)
Steve
My mitt died inthe washing machine. My mum wasn't very amused when the machine became clogged with loads of fluff, preventing the water from draining away properly :rofl:
once you have washed the car, wash the glove out in cold clean water or rinse it out under a cold tap.
