interior problems!
I'm trying to fit my new rear spax suspension but need to get to the top mount on the inside to undo the bolt! BUT, how do I get the interior rear side panel bits off in the boot? i dont just want to yank it and break it!
Can anyone give me some insite on how to remove it?
Cheers.
Hi mate, is it a hatch? If so therear strut is bolted into the rear arch with 2 bolts. Or have I got the wrong end of the stick?
No, estate, apparently you have to take the interior out in the boot to get to the top mount!
That's new to me, thought the Estate and Hatch share the same fitting points. i.e two bolts in the wheel arch holding the top of the shock up. May need to remove the plastic arch liner to get to the bolts.
ahh i may be wrong then!!! ill check it out tonight! cheers
