Two Fault Codes..
41F5 Vehicle speed signal plausibility
4664 Control unit incorrect coding
Theses codes magically appeared along with a check engine light after an oil change!
Anyone have any Ideas?
Ive cleared them but they always return...
Its a 2007 Octavia 1.4.
Regards,
Mark
Have you got a full copy of the error logs you can post? Those two don't look like the full codes I would expect.
Steve
This is all I have. attached as a picture
Also forgot to mention the air con stopped working also!
Its quite bizarre..
30145.attach
Ah right - what have you used to run the scan? Is a generic code reader?
I thought you'd used VAG-COM.
Steve
I only have VAG-COM for my older octavia so im using a program called
VAG Commander.
My vag-com cable doesn't support can-bus...
