corner fog light coding
Anyone know the long code for the cornering fog lights and the active when indicator on please?
That would depend on a lot of things… the model of car, the age of the car, the controller fitted etc.
It’s never a good idea to just copy a long code from one car to another without the relevant scans and ideally screen shots of the relevant Byte. being present.
If you are using a genuine Ross-Tech interface it should be in the long coding helper anyway.
  • 6 years later...
Does anybody knows how to code MK3 FL octavia cornering lights?
tried this one in below, but it was not working, on before FL MK3 was woring well...
Quote
Enabling cornering fogs with additional settings for vRS
This enables the fog lights to function as cornering lights.
Controller 09 - Central Electronics
16 - Security Access - enter 31347
10 - Adaptations
Change the channels listed below - scroll to just over halfway down the long list of adaptation channels to find them. Do them one after the other, and do not come out of the adaptations until you have finished. If you do, you will have to close the controller and go back in and enter the security access code again. If on a vRS you only want the outer 2 bulbs to function as cornering fogs, then don't alter the first two channels, just alter the two channels listed as additional for the vRS, which are for the outer two bulbs.
Change (5)-Leuchte12NL LB45-Lichtfunktion B 12 to Abbiegelicht links
Change (5)-Leuchte13NL RB5-Lichtfunktion B 13 to Abbiegelicht rechts
